Author Topic: Rear mats damp  (Read 1314 times)
Offline on-the-rampage
Rear mats damp
« on: 23 June 2012, 17:00 »
Hi I have a bora and just noticed rear mats are damp checked the front and they seem ok and can't seem to see where it is coming from any ideas please
NOT NOW CHIEF I'M IN THE f**kING ZONE
Offline barrym381
Re: Rear mats damp
« Reply #1 on: 23 June 2012, 18:23 »
open the doors and by the hinges there is a black nipple. This becomes blocked and therefore renders them useless and they end up storing water. By giving them a squeeze you should get all the cr** out and you should have cured the leak. Do to both sides and then dry out the footwells...
« Last Edit: 23 June 2012, 18:32 by barrym381 »
Offline harlemex
Re: Rear mats damp
« Reply #2 on: 23 June 2012, 18:29 »
outside?
Re: Rear mats damp
« Reply #3 on: 23 June 2012, 21:33 »
cheers i will have a look and try that i hate bloo** water leaks
Offline dstv
Re: Rear mats damp
« Reply #4 on: 24 June 2012, 10:26 »
I have the same problem with my golf. Where is the nipple you talking about.. My left rear mat is soak with water. Just happened about two days ago after the heavy rain. Could I have the same problem?
2000 GTI 1.8t AGU, neuspeed airfilter,Forge 007 dv, R-tech stage 1 remap, Silicone TIP,3" exhaust system, K03s turbo and a empty wallet.
Re: Rear mats damp
« Reply #5 on: 24 June 2012, 21:11 »
i cant see a nipple on mine just a big black bung with a little hole in
Offline Steve_PD
Re: Rear mats damp
« Reply #6 on: 24 June 2012, 21:14 »
Nipple is just below the top hinge. Every mk4 has them.
Looks like this
Offline dstv
Re: Rear mats damp
« Reply #7 on: 25 June 2012, 18:01 »
i dpont have that on mine. just the black bung ???
Re: Rear mats damp
« Reply #8 on: 28 June 2012, 21:02 »
heres what mines like
