Author Topic: Uprated 1.8 Turbo Exhaust manifolds.  (Read 4479 times)
Offline Scott-R
  • GoT BoosT!
Re: Uprated 1.8 Turbo Exhaust manifolds.
« Reply #10 on: 24 June 2012, 13:40 »
What would all the bolt-ons be? I think i probably got most of them? Not meth tho ha!
Golf GTI ... What else would you have?
Offline Dave_IOW
« Reply #11 on: 24 June 2012, 13:45 »
As said, a k04 relentless manifold will be no good for you, think badger5 will port your exhaust manifold for £80ish.
Will be plenty enough  :smiley:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline brianpologti
« Reply #12 on: 24 June 2012, 13:59 »
If you have a k03/s then you only need a ported stock manifold . They flow enough for well over 300bhp . Unlike the stock k04 manifold which is shxt compared with the tubular xs power one
Just get one ported , but mark sure it's un cracked before you send it away ,
All the performance ones for the ko3 crack , and can be a b!tch to fit and remove . I ve had two , ended up with standard ported.
Offline DunnDeal12
  • Limited
« Reply #13 on: 24 June 2012, 14:41 »
got my ko3 manifold ported and made no difference what so ever.
Offline Chris#101
« Reply #14 on: 24 June 2012, 15:44 »
Whats your spec ?
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Chris.
« Reply #15 on: 24 June 2012, 15:45 »
My 248bhp k03s was on stock manifold.
Click For Build Thread
Offline DunnDeal12
  • Limited
« Reply #16 on: 24 June 2012, 16:08 »
Whats your spec ?
agu ko3s 234bhp 266lbft with oem actuator
sorry just looked at my previous dyno printout with the un-ported manifold and there was a gain of 1bhp and 3lbft but this was on a freezing cold day.
Offline Scott-R
  • GoT BoosT!
« Reply #17 on: 24 June 2012, 19:21 »
So my cars in just now getting hopefully fmic and maybe few other wee things done.. Should i be lookin at near 250? Or more?
Offline littco
« Reply #18 on: 24 June 2012, 21:02 »
Whats your spec ?
At the figures your running , porting won't make much difference, will help with back pressure and keeping EGTs lower but it's not until you fit a hybrid or the like that porting comes into its own. The stock k03 manifold is pretty good unlike as I said the k04.
Offline DunnDeal12
  • Limited
« Reply #19 on: 24 June 2012, 21:19 »
its ok because just ordered a special hybrid off bill @ badger5 good for 325bhp
http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/144648-got-k03-s-installed-want-more-bhp.html
