Author Topic: how to fit a thermostat, haynes manual???  (Read 1785 times)
Offline billytheboot
« on: 15 June 2005, 00:33 »
Hello, could someone please help me... Just bought a thermostat for my hotter hatch 1989 Golf GTI 8v, could anyone give advice on fitting please? If I was organised I would have got hold of a haynes manual (big ask - could anyone scan the section) but haven't had the little beauty for long. Any help would be greatly appreciated
Re: how to fit a thermostat, haynes manual???
« Reply #1 on: 15 June 2005, 08:59 »
Removal
1 The thermostat is located in the bottom of the coolant pump behind the inlet elbow. To remove it, first drain the cooling system.
2 Unbolt the inlet elbow from the coolant pump and remove the seal and thermostat (see illustrations).
3 Clean the coolant pump and elbow of any scale or corrosion.
Refitting
1 Refitting is a reversal of removal procedure. Always fit a new seal.
2 On completion, refill the cooling system.
Just in case the Haynes description is a little vague, the thermostat is located in the housing on the front of the block at the bottom, on the other end of the bottom radiator hose :)
« Last Edit: 15 June 2005, 09:00 by rubjonny »
« Reply #2 on: 15 June 2005, 12:10 »
many thanks, i'll be getting on with that this afternoon.
Offline Organisys
  • Old and Slow...
« Reply #3 on: 15 June 2005, 12:25 »
1 Refitting is a reversal of removal procedure..
Where have I heard that before ?  :grin:
« Reply #4 on: 15 June 2005, 12:36 »
In the 'normally useless' haynes manual I bet ;)
