Author Topic: Mk3 head  (Read 1235 times)
Offline gizmomk3
  • on my way
Mk3 head
« on: 22 June 2012, 22:40 »
Found a AEE head off a polo 1.6 8v that will fit my mk3 golf is it worth getting it and recon it ??
What you lot thing??
Re: Mk3 head
« Reply #1 on: 22 June 2012, 22:50 »
What engine is in your Golf ?
Offline gizmomk3
  • on my way
Re: Mk3 head
« Reply #2 on: 22 June 2012, 23:44 »
1.6 8v AEE
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Mk3 head
« Reply #3 on: 23 June 2012, 11:26 »
Depends if your engine needs a new head  :grin:  I take it there is a problem with it?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline gizmomk3
  • on my way
Re: Mk3 head
« Reply #4 on: 23 June 2012, 13:10 »
Cam shaft is coverd in what looks like burnt oil where sum dick has I assume roped the oil up with the car hot or running
I was thinking get new head recon it in my own time over a month or 2 ok may be 3  :laugh: then fit as I need the car for work 6 days a week i could have the head swooped in half A day all going well that way
Offline Screech16v
  • MK3 20vt AGU
Re: Mk3 head
« Reply #5 on: 23 June 2012, 22:52 »
Topping the oil up hot or running will not cause oil to burn and stick to your camshaft  :laugh:
Some dick runnin it low on oil will though  :tongue:
Offline gizmomk3
  • on my way
Re: Mk3 head
« Reply #6 on: 23 June 2012, 23:05 »
I did not know that lol so I go from one extreme to another when a got the car sum tit had over filed it with oil as that were told by an old spanner monkey that it did not matter how much oil is in a car.
In the stone age it might not of don't but in 2012 6.5 litres  of oil is WAY to much what a tit
