Author Topic: Coilover setting up help  (Read 1543 times)
Offline Povey
« on: 22 June 2012, 20:38 »
Evening all,
Iv just fitted coilovers to my mk4 1.6 AZD and fitted the alloys bbs LM reps 18" 8.5j and the tyres are hitting the shocks? Someone said I will need 3mm spacers so I brought 5mm just to be safe and they still rub?
I want my car to be über low so on the rear iv taken out the adjuster and on the front they are wound right down!
Can I take out the helper spring and wind the lock nut right up? Or is there another way?
Offline cullygti
Re: Coilover setting up help
« Reply #1 on: 22 June 2012, 20:56 »
yes there is just take the coils off and you will be uber uber low  :cool:  :grin:
Offline Povey
« Reply #2 on: 22 June 2012, 21:11 »
What do the helper springs do? Will it affect the Coilover if I take them off?
Offline cullygti
« Reply #3 on: 22 June 2012, 21:20 »
im not sure mate tbh i think your as low as your gonna get it by removing the adjusters out but dont quote me on that as i may be wrong im sure iv heard of a few ppl removing the helper springs tho  :smiley:
Offline 1.6mk4GOLF16v
« Reply #4 on: 22 June 2012, 21:31 »
i had the same problem on my AZD last month when i put the coilies in, mine rubbed even with 5mm spacers, 7mm cleared it just about so i put 10mm hubcentric spacers  :wink:
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Offline Povey
« Reply #5 on: 22 June 2012, 21:34 »
What I can see is the spring is say 30cm long there's a shim then the helper spring say 10cm long then 2 lock nuts. With it wound right down the tyres hit the helper but picture this of I remove the helper spring and wind the lock rings up 10cm essentiallywinding them
Up to where the top of the helper spring would be it won't actually make the car any lower than is but give me ample room because the helper won't be in the way?
Offline cullygti
« Reply #6 on: 22 June 2012, 21:34 »
iv got 5mm on mine and no problems so they be fine
Offline Povey
« Reply #7 on: 22 June 2012, 21:53 »
Got any pics on he low it is? My coilovers are all the way down I mean last thread!
Offline AD1.8T
« Reply #8 on: 22 June 2012, 22:13 »
You sir would of found cullys thread thread the other day extremely usefull  :laugh:
Seriously though dont remove the helpers from the front it will give a hideous ride there designed to give the coilovers some softness you can get plenty low enough with them in taking the adjusters out the rear is fine but dont go chopping up the springs  :laugh: if i was you i would buy some 10mm hubcentrics and be patient untill there on...... If you do put the joms all the way down you will destroy under the car and it will look pants with the back end so high conpared to the front
Offline cullygti
« Reply #9 on: 22 June 2012, 22:39 »
yes that is correct as the front sits a lot lower than the rear mine are down all the way on rear with adjusters still in bump stops removed and i have 20mm left on the fronts but could do with raising them another 5mm to be more on par with the rear  :smiley:
and i wish ppl would use the useful guides from the thread a few days ago  :grin:
