Author Topic: HELP....1.8 NON TURBO STARTING FAULT  (Read 1162 times)
Offline sarge-1974
« on: 22 June 2012, 18:41 »
Hi got a mk4 gti 1.8 20v non turbo.only had it a few days and dont know much about the car.ive got a starting fault which seems to only happen when the engine is hot.leave car for half an hour to cool down and starts 1st turn of the key and runs fine.take it for a drive again get up to temp,turn it off and try again and the engine just turns over but wont start,immob light goes out and you can here the fuel pump.is there a common fault ??? can anyone help plz
cheers simon
Offline stfc_gti
Re: HELP....1.8 NON TURBO STARTING FAULT
« Reply #1 on: 22 June 2012, 18:51 »
did you buy private of dealer? if dealer take it back.
2002 1.8T GTI AUM, Standard (not for much longer)
Offline sarge-1974
« Reply #2 on: 22 June 2012, 19:29 »
private, ebay  :angry: starting to think this is why it was for sale
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 22 June 2012, 19:31 »
coolant sensor or crank sensor probably. you need vagcom or similar to tell for sure
Offline sarge-1974
« Reply #4 on: 22 June 2012, 20:34 »
thanks mates
Offline AcidicDavey
  • Not a VAG Owner.
« Reply #5 on: 22 June 2012, 20:58 »
Almost certainly a coolant temp sensor, my V70 was behaving just the same, it through up a coolant related code, new sensor and brum!
95 Volvo 480 2.0 Celebration
Offline mcgee9t2
« Reply #6 on: 22 June 2012, 22:49 »
+1 i have the same, hoping its the coolant cause its cheeper :D
Offline sarge-1974
« Reply #7 on: 23 June 2012, 19:43 »
thanks for all your help,had it checked today and it is the crank sensor.
thanks again  :cool:
