Author Topic: remote wire problems etc etc etc?  (Read 1246 times)
Offline golf1.8t
« on: 14 June 2005, 19:16 »
ok has any body had a problem with there remote wire when fitting an amp like the amp staying on?
and another thing i have a shed load of interferance?
now im getting well the subs are pulseating in and out like there playing but just a boom boom sound when the engine is to be started
help please be before i go out of my mind.
DUBBIN FOR LIFE:
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
Re: remote wire problems etc etc etc?
« Reply #1 on: 14 June 2005, 21:52 »
Are you sure the amps are wired to an ignition source, with a continuous feed?
The interference sounds like you are running your rca cables too close to your power leads, or there is a bad earth connection.
Try fitting an alternator suppresor, that sometimes helps :undecided:
