Right recently had my headgasket changed since then (2 weeks nearly) its been burning alot of oil (gone through about 7 litres of it!)
running wise, its great, accelerates fine etc
speaking to gary on here hes had a simular problem with his mk4....
on start up it smokes but not afterwards, then when warm and pulling off (1st to 2nd mostly) it smokes alot then.
weve both been pointed to either two things....
piston rings gone or valve steam oil seals (the oil seals were changed by the garage that skimmed my head)
iv done a compression test (with throttle wide open) and reading the following on the cylinders from drivers side across
engine is a abf if that matters..... 225, 240, 250, 260. which i know is high.
trying to find out as if its the piston rings il have to pay to get everything done, but if its the stem seals im getting the garage which did my head to pay (seeing as they put the new seals in)
any help will be great
