Author Topic: Suspension parts advice from the pros  (Read 1426 times)
Offline Lewisf1988-DUB
  • 1.8T AGU
« on: 21 June 2012, 08:36 »
Hi lads,
just purchased my bilstein b4 sport shocks and H&R springs the other week and am looking to fit them on Saturday, the below diagram shows the suspension setup for the mk4, when I put on my coilovers before I'm sure I missed out parts 28, 23 and 15, my question is will I need to buy new ones of these parts as I no longer have my old ones, when looking at ETKA online I found that parts 28 and 15 come in various options for the likes of sports suspension but they are the same part number. What parts will I actually need on this diagram, I have parts 20, 17, 16, 21, 18 and 14 what other bits would I require?
Thanks in advance :)
Offline old_n07
Re: Suspension parts advice from the pros
« Reply #1 on: 21 June 2012, 08:49 »
You will need everything in the diagram below (ignoring the hub itself) and you won't need the spacer (28) from your ETKA diagram
While you are doing it replace the rubber top mount and bearings with new ones (items 18 and 14 on the ETKA diagram)
The bump stop (item 15 on ETKA) can be got in variouse lengths depending on the suspension as you know, get one to fit the anni as it is shorter for the lowered suspension :afro:
« Last Edit: 21 June 2012, 15:22 by old_n07 »
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
  • 1.8T AGU
« Reply #2 on: 21 June 2012, 08:56 »
Solid advice, cheers for that mate   :smiley:
Offline 1.6mk4GOLF16v
« Reply #3 on: 23 June 2012, 23:33 »
pretty sure i didnt put part 21 in when i put my coilies on, is it essential?
is there an actual step by step to fitting coilovers as i wanna make sure ive done it right
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
« Reply #4 on: 30 June 2012, 12:02 »
anyone?
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
Offline DunnDeal12
  • Limited
