Golf mk4
Wazzzer
19mm to 15mm
Topic: 19mm to 15mm (Read 1869 times)
ade_aidy_ady
GTI forum regular
19mm to 15mm
20 June 2012, 20:15 »
if a catch can has 15mm outlets and heater hose being 19mm etc anybody any recommendations on where to get 19mm to 15mm hose reducers ?
jamie1989
Re: 19mm to 15mm
20 June 2012, 20:23 »
Done this myself, ebay is your answer mate.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
cullygti
Re: 19mm to 15mm
20 June 2012, 20:36 »
i had 19mm custom fittings made
jamie1989
Re: 19mm to 15mm
20 June 2012, 20:40 »
parrrr tooo posh mate.
not than im jealous haha
cullygti
Re: 19mm to 15mm
20 June 2012, 20:59 »
the reducer works just as well mate so dont know why i bothered
jamie1989
Re: 19mm to 15mm
20 June 2012, 21:04 »
yeah touch wood it hasnt been a problem for me. Im glad its done now.
jockgti
Guest
Re: 19mm to 15mm
Reply #6 on:
21 June 2012, 09:34 »
on one of my outlets i used electrical tape to make it a bit thicker so the 19mm pipe fitted fine ,but the outlets at the top of can were to close for 2 19mm pipes so i used 16mm on the other with a reducer in,got the 19-16mm plastic reducer on ebay
cullygti
Re: 19mm to 15mm
Reply #7 on:
21 June 2012, 09:35 »
it is a tight fit with 2 19mm fittings but can be done as i said it should work just the same with the reducer in place
Golf mk4
Wazzzer
19mm to 15mm
