Author Topic: Whats this for?  (Read 1719 times)
Offline GolfGL
Whats this for?
« on: 20 June 2012, 19:58 »
Hi, while fitting parts on my car today i came across a wire that comes from above the oil filter housing and then loops to the starter motor.
The wires have been rubbing and the covers broken so im going to have to do a repair with some heat shrink and find somewhere to put it.
So does anyone know what this wire powers?
And secondly how should it be routed to not rub like mine has
Thanks
Adam
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline stainesy
Re: Whats this for?
« Reply #1 on: 20 June 2012, 20:02 »
from what i can see in the pic it looks like its coming from down near where the dipstick comes from so could be your oil level sensor maybe?
Offline Stewy12
Re: Whats this for?
« Reply #2 on: 20 June 2012, 20:07 »
Crank shaft postion sensor mine is almost in the same place
Offline stainesy
Re: Whats this for?
« Reply #3 on: 20 June 2012, 20:13 »
ah yeah forgot about that.
Offline GolfGL
Re: Whats this for?
« Reply #4 on: 20 June 2012, 21:42 »
Damn i better repair this properly then. do either of you have photos of how it should look correctly routed.
Adam
Offline Stewy12
Re: Whats this for?
« Reply #5 on: 20 June 2012, 21:57 »
Mine runs the other side of oil filter
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Whats this for?
« Reply #6 on: 21 June 2012, 15:26 »
If the cable is damaged already the chances are you'll be replacing it sooner rather than later. Bloody things!
Offline Adam87
Re: Whats this for?
« Reply #7 on: 22 June 2012, 20:46 »
Perfect! spotted the same wire on mine at the weekend, all dry and crispy with insulation missing, I wonder if this could go some way towards my running issues  :grin:
Offline GolfGL
Re: Whats this for?
« Reply #8 on: 22 June 2012, 21:05 »
Sounds like there are multiple poor running issues on the mk3. Mine looks like the outer covering has cracked in places so the two wires could be connecting with each other. For mine i will just repair it as only one section felt brittle and then properly cover it to stop it rubbing
