Author Topic: Coolant leak  (Read 6260 times)
Offline Jamin
  • Mk3 Golf Gti 16v
Coolant leak
« on: 20 June 2012, 19:50 »
Hi dudes
Topped the car up with coolant the other day as the temp light was flashing. Literally 24 hrs later and the light was on again. I inspected the reservoir at it was empty. Had the day off work today so filled the expansion tank up with water and have discovered there is a leak coming from underneath the alternator at the bottom of the fan belt. Is this my water pump?? Is it common for them to leak when they are on the way out???
Help!!
Offline Stewy12
Re: Coolant leak
« Reply #1 on: 20 June 2012, 19:55 »
Sure is the water pump is in the casing easy to replace
Offline itavaltalainen
Re: Coolant leak
« Reply #2 on: 22 June 2012, 19:55 »
I got one lying around - complete with flange, thermostat and pulley.....
send me a message if you're interested.
Offline Jamin
  • Mk3 Golf Gti 16v
Re: Coolant leak
« Reply #3 on: 23 June 2012, 13:20 »
Ordering from Eurocarparts mate. Going to utilise  the 25% discount and would prefer to get new tbh
Really appreciate the thought though :smiley:
Re: Coolant leak
« Reply #4 on: 23 June 2012, 19:15 »
The one I have sitting around was in the car for only 2 weeks ;)
Scrapped it cos it needed new shocks and coils (as well as registering it in the UK) and I found another Mk3 estate in good shape.
