Golf mk4
Wazzzer
Rough Running 1.8T....Advice Please
Topic: Rough Running 1.8T....Advice Please (Read 3757 times)
jamie1989
Re: Rough Running 1.8T....Advice Please
Reply #20 on:
20 June 2012, 20:11 »
Cully pmd mate
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Dalo Harkin
Reply #21 on:
21 June 2012, 07:56 »
From what you have described I would say one of the coils have gone, easiest way to test is start the car unplug 1st one, engine revs should drop, plug that one back in its fine, do all 4 and if one doesn't drop its fooked
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
jamie1989
Reply #22 on:
21 June 2012, 08:02 »
Wont be coil packs on agu dude. Ignition amp is more common.
Golf mk4
Wazzzer
