Author Topic: Polo handles  (Read 3472 times)
Offline monkeyalan
Re: Polo handles
« Reply #10 on: 16 June 2005, 15:54 »
just been behind a 53 plate peugeot 206 sw estate and it looks like a possibility. not sure about the water spray tho.
Offline golfpro
  • If in doubt, pay someone else to do it!
Re: Polo handles
« Reply #11 on: 17 June 2005, 07:37 »
Dont think my early mk3 has a water spray atall, if it does it aint workin!
My wiper doesnt come out of the window either so maybe il be able to get round it.
Rear polo handles sounds like a good idea. Will they just swap over or will i need to do something if im not using the locks?
Do i risk removing my armour plates though?
thats the best mk3 ive seen..ever! its just clean and subtle.. :cool:
Offline monkeyalan
Re: Polo handles
« Reply #12 on: 17 June 2005, 12:10 »
from what i understand the handles are just a straight swap. If i were you i'd check behind the plates before i spent any money.
Offline golfpro
Re: Polo handles
« Reply #13 on: 17 June 2005, 13:02 »
good thinkin alan. Thats the kinda thing i normally forget to do and i end up spendin double what i need to.
Will speak to a friend of mine and see what i can do. Got my heart set on these now, they better bloody fit!
Offline monkeyalan
Re: Polo handles
« Reply #14 on: 17 June 2005, 14:58 »
seen 'em done loads in mags so should be no probs. i'll be doin mine late in the year too.
Offline Nickyb
Re: Polo handles
« Reply #15 on: 17 June 2005, 15:13 »
The Haynes manual says the door handles are removed by removing the bolt on the door in the door shut, put the key in the barrel and unlock the door when it is open and that will release the door handle from the mechanism along with the armour plate. Then remove the right hand side of the handle by pulling away from the door??
I wonder if it is that simple? I doubt it :grin:
I think locating the locking barrel back on the rod inside the door on installation will be the hard bit. :undecided:
Offline monkeyalan
Re: Polo handles
« Reply #16 on: 17 June 2005, 15:26 »
haynes always forget to put
Fig 3a " shout obscene words at inanimate object, throw to floor, ask relevant deity what you did to deserve this, go to kitchen to find plaster for fresly damaged knuckles..."
