Author Topic: WARNING dash led bulbs  (Read 2270 times)
Offline ianmaxtec
« on: 20 June 2012, 13:18 »
I decided to replace the bulbs in my clocks (86 mk 2 gti), as one was blown. So I went down the road of LED’s, thinking that it would be ages before I would have to change them again. The bulbs I bought did more damage than good, as the contact edges were very sharp, and when you twist them through 90 degrees they cut a grove across the tracks passing the bulb holders. Upon inspection I realized that the contacts on the bulbs were just strips of steel with the end folded up to leave a really sharp point, which did the damage to the tracks on the circuit board. I ended up repairing what used to be a perfect foil circuit board, and then put a drop of solder on each contact on the bulbs, they then twisted smoothly into place and worked fine. My advice is make sure that the replacement bulbs have nice smooth contacts and NOT a knife-edge like the ones I bought. What an ordeal, what should have take an hour at best took half a day. The worst part was the damage to the foil, it will never be the same again!!!!!!!
Offline X4MGS
  • VAG Parts SNOB!!!
Re: WARNING dash led bulbs
« Reply #1 on: 20 June 2012, 13:22 »
I could have told you that.... Pity you didn't ask 1st!!
The bulb holders are not a standard fit...
There is a Guy (T~L~C) on here and ebay does a proper set of replacements...
For More Info Click To See;
Offline ianmaxtec
« Reply #2 on: 20 June 2012, 14:19 »
I assumed they were all the same, the ones I got were cheap SH*T from ebay, live and learn
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #3 on: 20 June 2012, 15:08 »
I found out after I bought some for my Audi (Which did work) and tried to fit them to a duff set of clocks I had...
Like you say live and learn... "Every day is a school day"
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #4 on: 20 June 2012, 15:47 »
Sometimes Forums can come in useful :rolleyes:
Thom
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #5 on: 20 June 2012, 15:48 »
Thom
This one always is M8.... Unlike OTHERS.... :laugh: :laugh: :laugh:
Offline Thom89
« Reply #6 on: 20 June 2012, 15:50 »
Thom
Whatever  :grin: :grin:
Thom
