Author Topic: GTI T Exhaust manifold.  (Read 972 times)
Offline dickgam
« on: 19 June 2012, 18:26 »
Hi,
Just been told that my exhaust manifold may have a crack in it, hard to determine as there is so much stuff in the way, is this a common fault. What would be everyone's recommendation? Go with a standard manifold or is there something else that will mate upto the standard system that won't cost the earth? The car has the AUM engine.
Thanks for any comments. :cool:
Re: GTI T Exhaust manifold.
« Reply #1 on: 19 June 2012, 23:46 »
Someone that knows what they are doing may even be able to weld your one up.
Offline dickgam
« Reply #2 on: 20 June 2012, 06:21 »
Hi,
I was advised not to weld it up as it may crack again, it someone has to go to the trouble of removing it then I would prefer a new one. I have just looked on fleabay, there is one made from tubes rather than cast, it might be worth a look at.
I should have put a link in.
Thanks.
« Reply #3 on: 20 June 2012, 10:49 »
I would stick with the standard manifold.
