So you put a 2.0 engine in a 1.6 changed loom so on so on but have you changed the ecu to match the engine as the 1.6 is SPI (single point injection) and the 2.0 is not so this could be a problem as it has more to do...If not you will need
ECU from AGG/ADY Depending on engine code and poss the immo box and chip unless you can recode it with vagcom or a early ECU for a 2.0 which didnt come with immo
Relay 30 or 32
