Author Topic: mk2 vr6 query  (Read 4509 times)
Offline mush
mk2 vr6 query
« on: 19 June 2012, 10:09 »
i was just wanting to gather some information from a few people that might of done a mk2 vr6 or have a bit more knowledge than me on this conversion.
my main question was the front engine mount, how many people run a standard front engine mount how useable is this and any dangers of running this knowing the vr6 is a lot more weight than an 8 or 16v
MK2 golf 16v :-)
Offline jmsheahan
Re: mk2 vr6 query
« Reply #1 on: 19 June 2012, 10:37 »
Sorry to link to another forum but this may be of use - lots of info: http://mk2vr6.com/board/index.php
Offline cняis
Re: mk2 vr6 query
« Reply #2 on: 19 June 2012, 20:54 »
Best advice I can give is either use Corrado VR6 front crossmember (with corrado engine mount), which can be difficult to source, or use the existing mk2 golf crossmember with a specially made mk2golf/vr6 solid engine mount. You can buy them occasionally on ebay or from a member on mk2vr6.com
Offline clipperjay
Re: mk2 vr6 query
« Reply #3 on: 19 June 2012, 21:46 »
I thought a MK2 1.3 front engine mount fits (low profile) could be chatting crap here?
Online CM690
  • Golf MK4
Re: mk2 vr6 query
« Reply #4 on: 19 June 2012, 22:37 »
Offline JamesS
Re: mk2 vr6 query
« Reply #5 on: 20 June 2012, 11:53 »
I wouldn't run anything less than a standard vr6 front engine mount. For the conversion I used corrado vr6 subframe, front cross member & rad mount, everything just bolts straight up it's easier than easy. There is always a corrado vr6 being broken on ebay.
For the front engine mount on my mk2vr6 I started with a mk3 vr6 front mount. I bought a large polyeurethene chopping board and used a circle cutter to cut out discs of the chopping board. (you can also use hockey pucks) I took the mount apart, cut 2 x slices of about 15mm from the original rubber which were used at the top and bottom of the new mount. Filled the space in between with the polyeurethene discs to required height.
I haven't had any problems having run the car for 15k+ over two years. It's stiffer than standard and there is no cabin vibration having used two slices of the original rubber. I did the same thing to the rear engine mount which has to be taken apart and reduced in height by 20-30mm so bonnet clears the engine. Best bit is that it only cost £2.99 and does the same thing as engine mounts which cost £200+ for a set.
Wiring is the hardest part of the swap. The mechanicals are simples.
For the conversion I used corrado vr6 subframe, front cross member & rad mount - always a corrado vr6 being broken on ebay.
AEROSPACE GRADE CNC MACHINED VR6 KEYRINGS. ONLY £16.50 INC P&P.
http://www.mk2vr6.com/board/viewtopic.php?f=28&t=13053
Offline mush
Re: mk2 vr6 query
« Reply #6 on: 20 June 2012, 12:27 »
cheers for all the replies, james i might be picking on you for advice if you dont mind. i was keeping this a secret from you guys however theres always some question that needs answering that have already experienced this but the cats out the bag now. ive got to say its going to be very quick had a go in the donor car before taking it off the road and gosh its quick, will be even quicker in the mk2. if you fancy coming to help just let me know will give you some bucks.
ive got the obd1 vr6 which is going in my 91 mk2 golf any advice would be awesome dudes.
erm to cm690 - thanks ive emailed the guy thats selling the solid mount
james how long did your install take?  i was planning 3months  :cool:
MK2 golf 16v :-)
Offline JamesS
Re: mk2 vr6 query
« Reply #7 on: 21 June 2012, 11:42 »
It took me around three weeks after all parts were collected. Time taken depends how thorough you are going to be. A straight swap with no cleaning, renewing of parts and painting can be done over a weekend if no problems are encoutered (unlikely:grin:). I cleaned up all subframes and the engine bay, painted everything and installed loads of new parts etc.  All in the engine conversion and painting of parts and bay etc cost around £600.
You should get good results if you plan on doing it over 3 months.
Offline mush
Re: mk2 vr6 query
« Reply #8 on: 21 June 2012, 12:22 »
thanks james you've just boosted my confidence loads day off tomorrow so next is to disable the airbags on the vr, some guy made me laugh on here when he said put a helmet on and arm yourself with a big hammer  :laugh:
MK2 golf 16v :-)
