Author Topic: auq ecu on aum?  (Read 4391 times)
nath20vt
auq ecu on aum?
« on: 18 June 2012, 23:21 »
hi everyone, heard a few times you can run a auq ecu on a aum engine for the extra 30 horses out of the box, just want to no how true this is as need a new ecu so if its true will be purchasing the auq one.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: auq ecu on aum?
« Reply #1 on: 19 June 2012, 07:13 »
for all the time and hassle just get your AUM remapped...
nath20vt
Re: auq ecu on aum?
« Reply #2 on: 19 June 2012, 14:57 »
hmm wont be much hassle really if its just a case of getting the immobiliser removed and plugging it in?
Offline Scott D
Re: auq ecu on aum?
« Reply #3 on: 19 June 2012, 16:59 »
unless you can pick up an AUQ ecu for mega cheap would be more worth while having a remap and 20ish more horses.
fairly sure its just a case of sorting the immobilizer either removing or adapting to work with current speedo cluster & keys.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
nath20vt
Re: auq ecu on aum?
« Reply #4 on: 19 June 2012, 21:44 »
hi mate thing is a bought a conversion and me bein a fool never checked the ecu number, when i came to fit it its a ecu off a 1.8 non turbo and the fella who sold me the conversion is being a right pr**k about it all saying im trying to give him my old ecu ect ect when he genuinly gave me the wrong one, so im going to have to buy a aum ecu either way so just thought i may aswell buy the auq one and have the extra 30 horses already there as i will be keeping it standard for a while before i get it remapped ect, so would i be able to programme a auq into my clocks and key and everything? was goin to just get the immob removed but if i can get it set up properly with immob working id much rather do that
Offline golf-sib
  • Турботазик
Re: auq ecu on aum?
« Reply #5 on: 19 June 2012, 21:48 »
Depends, you looking at getting a map further down the line?
If so go which ever one is cheaper. I believe they are the same ECU (bosch 7.5), but don't take my word for it, during the span of the AGU there was like 12 revisions  :grin:
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline AD1.8T
Re: auq ecu on aum?
« Reply #6 on: 19 June 2012, 21:57 »
I asked this a little while ago and the ecu is still available to me surelly it would just be a case of matching it up with the clocks and keys ?
nath20vt
Re: auq ecu on aum?
« Reply #7 on: 19 June 2012, 21:59 »
i will be getting it mapped eventually but wont be for a couple of months or so, im the same i no someone who can remove the immob for me but id much rather have it matched into to clocks key ect so the immob still works
Re: auq ecu on aum?
« Reply #8 on: 19 June 2012, 23:45 »
Just run it on a AUM ecu much less hassle.
