Author Topic: Another happy R-Tech Customer  (Read 3944 times)
Offline Chris#101
« on: 18 June 2012, 18:31 »
This has been well over due but I cant believe now after knowing how much difference its made why I put it off for so long. It took me the best part of 3.5 hours to get there but boy was it worth the drive, especially on the way home  :shocked: :cool:.
As soon as I got there the guys got stuck in checking everything was all good and safe then explained what was going to happen :smiley:.
In the first 30-45mins session on the dyno the guys maxxed the set up out at 199bhp  :huh: with a missfire.  How ever after they had a quick look around they soon noticed that I had made a school boy mistake by not tightening something on the intake manifold allowing a boost leak. Within the next 1hr 30 mins they switched the engine off and started undoing the safety straps to get the car off the dyno. With the new live software they have everything can be done twice as fast so to say I was itching for a drive was an understatement.
Even though it was way above my head they took the time to explain they had *maxxed my set up out  :laugh: showing me all the figures, duty cycles etc etc. I then went on a test drive  :laugh: and wow.... I told my friends I was getting a new car to throw them of the scent but this is just as good as. it really is completly different to before. you only have to feather the throttle to cruise and then if you push a bit more it absolutely transforms the car into something else  :grin: The power is soo smooth yet agressive its hard to explain. Overall I am soo happy with what the guys at R-tech have done, cannot recommend them enough  :cool: if your reading this guys, I will be seeing you very shortly with with larger 2.5" intercooler pipework, New turbo-maifold gasket + air filter :evil:.
Now the bit youve all been waiting for.
They maxxed out my set up with 1.75" intercooler pipework being restrictive :cry:. They said theres easily another 10+bhp to be had with the 2.5" pipework along with + lbft. They couldnt physically get the K03s to flow any more through the 1.75" pipework as heat soak was becoming a major issue even with the meth injection and F.M.I.C. I also had a leaking turbo-manifold gasket which you could hear which of course was loosing a bit of power along with a blocked/rusty toyosport air filter  :sad:. Either way Im extremely happy with the power they made considering the above and will be getting all the above sorted asap for another trip up there to get some better results along with launch control being added and left foot brake and boost  :laugh:.
The most important bit  :cool: 231bhp & 258ftlb holding a solid 20spi boost  :laugh:
R-Tech are busy for a reason people, I wouldnt go anywhere else  :smiley:
thanks
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline mar_k
Re: Another happy R-Tech Customer
« Reply #1 on: 18 June 2012, 20:19 »
Any pics of your car?
Whats the full spec your running?
Offline Chris#101
« Reply #2 on: 19 June 2012, 12:24 »
Pictures can be found in my project. Have only just started on cosmetics as I wanted performance done first
http://www.golfgtiforum.co.uk/index.php?topic=222223.0
Spec
* 2003 AUQ180
*90k miles
*K03s
* Momentum 99' RON fuel
*DEVILSOWN 6-30 PSI W.M.I kit
*CRAFT '42  3" turbo back non res exhaust system
*TOYOSPORTS C.A.I
*TOYOSPORTS F.M.I.C
*FORGE T.I.P
*FORGE actuator yellow spring
*FORGE 007P (soon to have)
*PCV simplified - oil catch can
*N249 valve delete
Offline Mr GTD
« Reply #3 on: 23 July 2012, 10:31 »
Great results Chris
Offline Toby
  • Car - less
« Reply #4 on: 23 July 2012, 18:23 »
awesome!
few more tweeks once uv got the correct size pipework, and maybe bigger injector's! and ur see 240+ probs!
nice results!
Great results
Currently down under
