Author Topic: Extra side lights...  (Read 1276 times)
Offline MattJAbela
« on: 18 June 2012, 12:18 »
Hi guys
My mk3 gti has aftermarket indicators with sidelights in them, like an actual seperate bulb, just wondering if to wire these in you just latch in to the sidelight loom?
Thanks
Offline dubstar9
  • Back to the Golf scene
Re: Extra side lights...
« Reply #1 on: 18 June 2012, 13:03 »
Yes you could or pick up an ignition live and run them as DRL's :wink:
Offline MattJAbela
« Reply #2 on: 18 June 2012, 13:55 »
Hmmm...now you've put that idea in to my head ;)
So one of the cable would be put to live, and the other to earth? Any idea what an ignition live would be??
Offline dubstar9
« Reply #3 on: 18 June 2012, 14:11 »
If you have a test light or multimeter switch the ignition key to the last position before starting the engine, drop the fuse box cover and test the fuses. Find one that is live and then switch it back one notch on the key and see if it goes out, if it does find out what the fuse is for. If it runs to the engine bay great, if not note which fuse it was and test another until you find one, if there isn't you have listed the one that run live on the last notch of the ignition.
You can tap into this live at the fuse box and push the wire through the engine loom gromet into the engine bay and up to the lights. Fingers crossed you should find a ignition live in the engine bay to tap into but can't think of one right now. :rolleyes:
