Author Topic: RCD 300 issue  (Read 2166 times)
Offline Newboy78
RCD 300 issue
« on: 17 June 2012, 18:57 »
Hi,
I've just bought a '06 plate mk5 Golf GTI and I am having problems with the RCD300 radio.
I have good FM reception, but no AM reception. It simply scans all the time, but does not pick up any stations.
I have run a test by holding down the menu button and it says that ANT1 is 'OFF' and ANT2 is 'ON'.
Signal strength shows as 'POOR'.
I've read that there are 2 aerials in the car, but I'm don't know how to acesss either.
Any ideas on how to turn ANT 1 on and would this help solve the problem?
All ideas gratefully received.
Thanks,
Newboy 78
Offline matping
  • MK1 20vT MK5 GTI T
Re: RCD 300 issue
« Reply #1 on: 17 June 2012, 23:10 »
hi there im pretty sure the fm transmitter is built into the back windows its the lines that go down not across
Offline Mr GTD
Re: RCD 300 issue
« Reply #2 on: 23 June 2012, 00:08 »
If you haven't resolved your issue yet, it might be worth posting your question in the garage section as you will get more responses...
Offline GUMBALL3000
Re: RCD 300 issue
« Reply #3 on: 23 June 2012, 12:12 »
Welcome mate!!
