Author Topic: squeaky clutch pedal  (Read 2233 times)
Offline gitvirgin
« on: 17 June 2012, 10:47 »
hi all
very almost got myself a GTI... only problem is... while test driving it i notice the clutch pedal squeak every time i press it right down to change gear, there is no change in the feel of the the clutch or pedal or even the way it drives, but it squeak and it annoying... now, am i being a right n*b  and is a simple matter of some WD40, or is it a more serious issue? :cry: :cry:
« Last Edit: 17 June 2012, 10:50 by gitvirgin »
Offline gitvirgin
Re: squeaky clutch pedal
« Reply #1 on: 19 June 2012, 22:30 »
no reply?
Offline barrym381
« Reply #2 on: 19 June 2012, 23:24 »
seen a few pedals snap right off
Offline gitvirgin
« Reply #3 on: 20 June 2012, 08:03 »
it's on a 11 plate mk6
« Last Edit: 20 June 2012, 08:18 by gitvirgin »
Offline ScottA
« Reply #4 on: 20 June 2012, 08:50 »
if it's from a main dealer get them to fix it
if it's from a private seller, buy it and get VW to fix it
shouldn't be squeaking and it's still under warranty, if that's the only problem then it can be fixed?
Offline stfc_gti
« Reply #5 on: 20 June 2012, 14:06 »
just turn the stereo up until you cant hear it, worked a treat in my old pug
2002 1.8T GTI AUM, Standard (not for much longer)
Offline BarryMKIV
« Reply #6 on: 20 June 2012, 16:15 »
25th Anniversary GTI 1.8T No. 0441
Offline ScottA
« Reply #7 on: 21 June 2012, 10:22 »
......but it's under warranty, you don't have to turn the music up or WD40 it, get a dealership to fix it  :rolleyes:
