Author Topic: Hot oil smell  (Read 2091 times)
Offline gizmomk3
  • on my way
Hot oil smell
« on: 15 June 2012, 23:33 »
I keep smelling hot oil when the car is up to temp my rocker cover is leaking i take it it is that I can smell??
All so the car is very Tapper tey in tick over had a look in the oil filler cap ind there is black burnt oil on the cam shaft do I
A take head off and recon?
B take rocket cover off and just cleane cam shaft??
Offline itavaltalainen
Re: Hot oil smell
« Reply #1 on: 16 June 2012, 00:00 »
Oh you got a Golf there......  :cry:
One one thought - change the rocker head gasket, the oil is leaking on your manifold causing the smell when hot... Just change it, here's a how to for a 1.8 but similar on yours:
http://www.golfgtiforum.co.uk/index.php?topic=229781
next thought - all the troubles you're having on daily or weekly basis with your golf, i'd be looking for another one....
the tapping noise you hear is from the hydraulic followers, focked due to using sh!te oil... cleaning the cam won't change anything (if you actually needed to clean the cam, bin the whole car immediately).
Offline gizmomk3
  • on my way
Re: Hot oil smell
« Reply #2 on: 16 June 2012, 00:18 »
Getting shut of the car is not an option work has put me on days there for down £300 a month so I'm skint rocker cover will get changed and oil change agane with good oil not this semi sh!t then take it from there if she gose bang then she gose bang not much I can do lol
Offline Jasikasisback
Re: Hot oil smell
« Reply #3 on: 17 June 2012, 11:03 »
Look at you injection flange mount. Mine was leaking and thar might cause a similar smell.
Offline nolandubholmes
Re: Hot oil smell
« Reply #4 on: 18 June 2012, 10:43 »
get some lucas engine oil stabiliser slammed in there after a good engine flush with a good quality oil and the lucas stuff u should be right its like gold for ur engine 15 quid a litre mind u it needs to be but i swear by it
aum no spec as no matter what i do il never be happy
Re: Hot oil smell
« Reply #5 on: 18 June 2012, 20:41 »
I do not like engine flush but in your case I would give it a try along with fresh oil and filter.
Offline gizmomk3
  • on my way
Re: Hot oil smell
« Reply #6 on: 18 June 2012, 21:05 »
So the plan is new rocker cover gasket engion flush and good oil and new filter
Yes??
Re: Hot oil smell
« Reply #7 on: 18 June 2012, 21:07 »
Yes??
Yes, has to be worth trying
Offline gizmomk3
  • on my way
Re: Hot oil smell
« Reply #8 on: 18 June 2012, 21:12 »
Right I'm on it thanks lads will keep you up to date
