Author Topic: vinyl wrapping  (Read 11407 times)
Offline gtiballs61
  • Wanted-nearside wing in lp3g(flash red)
vinyl wrapping
« on: 15 June 2012, 21:10 »
Ok so i have decided to wrap the mk3.
I am going to go for a matt sky blue,something like this:
Im in two minds as to whether or not to put the trim back on  :undecided: also should i leave the rims silver or go black?
« Last Edit: 15 June 2012, 21:30 by gtiballs61 »
Offline DUBboi12
Re: vinyl wrapping
« Reply #1 on: 15 June 2012, 21:12 »
I was thinking of doing the exact same thing  :laugh: so it would be cool to see how it comes out, I was thinking of putting the trim back on and also I think keep the wheels silver. Looks cleaner in my opinion
Offline stainesy
Re: vinyl wrapping
« Reply #2 on: 15 June 2012, 21:23 »
are you doing the wrapping yourself? white wheels would look sick with that colour  :wink:
Offline gtiballs61
Re: vinyl wrapping
« Reply #3 on: 15 June 2012, 21:27 »
yes mate,me and a mate are gonna have a shot at it :lipsrsealed:
I believe you did your bonnet? any tips for us stainsey?
We got 2 heat guns,alcohol rub and a few other bits.
Offline DUBboi12
Re: vinyl wrapping
« Reply #4 on: 15 June 2012, 21:31 »
A lot of patience lol
Offline DUBboi12
Re: vinyl wrapping
« Reply #5 on: 15 June 2012, 21:33 »
Offline stainesy
Re: vinyl wrapping
« Reply #6 on: 15 June 2012, 21:41 »
i have done loads of vinyl work as used to work for a sign company and was mainly using vinyl.
ok the serface needs to be very clean and totaly smooth mate. rub it over with a good degreaser and dont let a single bit of dust or anything on it. if you are doing a big bit like a bonnet lay it on the bonnet where you want it and fold it in half right down the middle from windscreen to tip of bonnet. so its all folded over on one side of bonnet. then peed the backing off and cut. then slownly work your way from the middle out doing one side at a time. if you get a bad crease lift it back off stick your hund under it and lightely use the heat gun on it and the memory in the vinyl will take the crease out. then once one side is done to the edge fold back the other side and do the same. then work your way round rubbing over the edges and cut around leaving about 15mm over hang. slit the corners outwards then use the heat gun gradually round to fold it under.
the places where you will have problems is once you get to the wheel arches. hard to explain hoe to do them but just remember you can alway bull it back up and use the heat gun plus your hand under it to get the creases out.
hope this helps mate. :wink:
Offline search
Re: vinyl wrapping
« Reply #7 on: 15 June 2012, 21:45 »
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline gtiballs61
Re: vinyl wrapping
« Reply #8 on: 15 June 2012, 21:50 »
the ones before look good but this one on ebay i dont like.
http://www.ebay.co.uk/itm/110897009553?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_500wt_1202
Too much blue,the bumper strips need to be black,a little black will help break up the blue.
@ stainsey,nice one bud :kiss:
« Last Edit: 15 June 2012, 21:53 by gtiballs61 »
Offline stainesy
Re: vinyl wrapping
« Reply #9 on: 15 June 2012, 21:52 »
how come you are choosing blue mate? something i have alway wanted to do is matt white.
