Golf mk3
hardmonkeys
cost to replace steering rack on 1.4?
Topic: cost to replace steering rack on 1.4? (Read 1916 times)
ryanbrook
GTI forum regular
15 June 2012, 16:16 »
Steering rack is on its way out i think. Steering is all over the place. Tie rods have been changed and i have a feeling its the rack. How much would it cost to replace it ?
mrsaunders
Re: cost to replace steering rack on 1.4?
15 June 2012, 16:42 »
A garage will charge silly money for it
Bandit127
Here all the time
15 June 2012, 17:31 »
Did you get the tracking checked? Bad tracking can make the steering feel as loose as hell. I had this on a previous car and I was convinced something serious had broken.
Tracking fixed it.
For £25, try it before you go for an expensive rack.
ryanbrook
GTI forum regular
16 June 2012, 14:50 »
Had the tracking done not so long ago mate, i thought it fixed it, but no joy. Its as loose as hell, dangerous to be fair.
F17BAD
Forum addict
Golf MTM S3 GTI TURBO
16 June 2012, 17:00 »
bottom arm bushes ?
Not no ordinary GTI....
www.mixcloud.com/kells/
Screech16v
MK3 20vt AGU
16 June 2012, 17:42 »
Quote from: F17BAD on 16 June 2012, 17:00
bottom arm bushes ?
^^^ this is what i would be checking first look for perished rubbers,can check by trying to get the wheel to move back and forth in the wheel arch,get a socket and bar on a wheel nut(car on the ground ,handbrake on) now put a bit of pressure on asiff to tighten/undo the wheel but not actually cracking them off.should have minimum movement,not excessive. Check the rack though, jack the front up, get someone to rock the steering side to side very slightly whilst you hold the road wheel ,if the steering wheel moves and road wheel doesnt then you have play in the rack or track rods on rack side.
Wayne
Sir Postalot
Reply #6 on:
16 June 2012, 22:03 »
To replace the rack is a major job, get a friend to move the steering wheel and have a look at the rack, you will soon see if you have any play.
Golf mk3
hardmonkeys
