Author Topic: Reverse camera - Screen corruption  (Read 3956 times)
Offline squirrelGTi
« on: 15 June 2012, 15:49 »
Hi guys,
Anyone seen this issue before? The only way i can describe it is it's like screen corruption.
Camera was fitted direct from the factory. It's done it about 4-5 times since new.
Gone GTi | 3dr | Manual | Carbon Grey | Xenons | Monza 18's | RCD 510 |Rear Camera | Winter Pack.
Jimmymature
Re: Reverse camera - Screen corruption
« Reply #1 on: 15 June 2012, 16:51 »
I've had a blue screen but nothing like this.....
Cheers,
Jim
Offline Jimble
« Reply #2 on: 15 June 2012, 17:11 »
I have an issue with the lines not being in the right place ie slightly over to the right but nothing like that! Get it to the dealer before your warranty expires!
Offline sundaydriver
« Reply #3 on: 16 June 2012, 11:28 »
Have you tried re-booting the RCD510?
« Last Edit: 16 June 2012, 11:30 by sundaydriver »
2012 Golf R, APR STAGE 2+, BCS power valve TB exhaust, loba HPFP, evoms intake, Rising blue, 19" Talladegas -BMW M2
Offline Mr_F
« Reply #4 on: 16 June 2012, 12:40 »
I've seen it on a prius rental in the states, my moneys on water in the connection.
61 Plate GTD 5dr, Shadow Blue, 18" Charleston's, Flat Tyre Indicator, Cruise Control, Bi-xenon (With Dynamic Curve), Storage Pack, Winter Pack and RCD 510.
Offline Jimble
« Reply #5 on: 16 June 2012, 14:34 »
How do you do that then? Might be worth me trying it to see if it lines me up?
« Reply #6 on: 16 June 2012, 14:49 »
On mine i press and hold the <> buttons and then press the star button.
Offline Jimble
« Reply #7 on: 16 June 2012, 15:00 »
I suppose you'd press the note button instead of the star button on the RCD then?
Offline gman86
« Reply #8 on: 18 June 2012, 13:38 »
Looks like the signal cable is damaged. It's a coax cable that supplies the vid, and if the grounding fails then it can put the signal out of sync. Remove the HU and check the connection at the back, make sure the outer shield foil isnt touching anything, and to the same at the camera end...
Or give it back to VW if its under warranty.
Offline squirrelGTi
« Reply #9 on: 18 June 2012, 14:52 »
Thanks for your replies guys.
I've got a service booked on the 29th June so i'll get them to take a look. I don't wanna bork anything.
As i say, it doesn't happen much.
