Author Topic: Idling  (Read 4490 times)
Offline benjam_in
Idling
« on: 05 April 2003, 13:25 »
Just brought a MK2 Gti and it has a small problem on idle. The engine seems to be hunting for a good idle speed and revs round to 2000rpm then drops right down. Anyone got any ideas of what causes this / how it can be resolved?
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
Golf Mk2 Gti 1988
Offline richandhazel
Re: Idling
« Reply #1 on: 05 April 2003, 14:37 »
If you have the Difigant fuel system have a look at table d here:-
http://homepage.ntlworld.com/richandhazel1/Difigant/Difigant%20II%20and%20I%20troubleshooting.htm
I'd go for cleaning the Idle stabilization valve first off.
For more information on the ISV, go here:-
http://homepage.ntlworld.com/richandhazel1/ISV/index.htm
Let us know how you get on.
« Last Edit: 01 January 1970, 01:00 by -1 »
Offline Bdub
Re:Idling
« Reply #2 on: 24 June 2003, 12:22 »
I had a simillar problem on my 89 8V.
Cleaned the ISV with carb cleaner - reset the idle ( by turning the idle screw in the throttle body, it's a good idea to remove this altogether, clean it with carb cleaner and squirt some into the hole before placing it.
You then need to start the car - remove the temp sender plug, rev the engine to over 3000rpm 3 times, replace the temp sender plug and rev again 3 times to over 300rpm - idle should now be stable.
This sorted mine.
