Author Topic: Alloys rubbing when braking?  (Read 2062 times)
Offline search
« on: 14 June 2012, 19:06 »
hey guys actually a mk3 Driver but as i have four studs though some of you may be able to help. got some ATS cups today put some part worn tyres and now when i brake theres this odd noise i assume the wheels as its a rotation noise at the same speed as the car, the only things i think it might be is 1) weights might be hitting the brake
                                                2) 195/50/15 tyres are rubbing somewhere?
                                                3) car to low? (not low enough in my eyes lol.
the alloys are ET28 7j15.
if anyone can help advice me that be great THANKS!
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline murraymint
Re: Alloys rubbing when braking?
« Reply #1 on: 14 June 2012, 19:08 »
As said before bud, go n have a look at the tyres, see if there are any marks from rubbing,
josh
Offline search
« Reply #2 on: 14 June 2012, 19:16 »
just seen that reply, cant see or feel anything. but as they are only on today i assume its to soon to tell. lowering my car a bit more on the weekend so ill have a good inspection on the wheel.
if it turns out wheels are rubbing what can i do to fix it?
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #3 on: 14 June 2012, 19:24 »
If it was a wheel/brake clearance issue it would be rubbing all the time. As said you need to get the wheel off and look for signs on rubbing somewhere. it should be quite obvious I would imagine. Can't see it being the driveshaft as your not that low but check anyway.
Offline Martz
« Reply #4 on: 14 June 2012, 21:08 »
Have you checked this?  If its consistant with the speed your doing then it is a high chance this is the issue. :wink:
Offline Jimmyrallye
  • 20vt goodness
« Reply #5 on: 15 June 2012, 10:08 »
Think you should sell your wheels to me problem solved ;)
