Author Topic: Creaks and squeaks  (Read 2378 times)
Offline jamesblonde
  • VW Golf Mk4 Estate 1.6 16v Tornado Red
Creaks and squeaks
« on: 14 June 2012, 08:39 »
when turning or going over bumps in the road i get creaks. i haven't got power steering so i didnt know whether the steering rack needed lubing up but i'm a bit of a novice.
Offline stainesy
Re: Creaks and squeaks
« Reply #1 on: 14 June 2012, 08:58 »
Its it the same sound when turning and going over bumps? Also where does it sound like the noise is coming from?
Offline jamesblonde
« Reply #2 on: 14 June 2012, 10:24 »
Yeah it is yeah. And seems to be coming from the drivers side more than the passengers
Offline stainesy
« Reply #3 on: 14 June 2012, 10:54 »
Could be a top mount. If its doing it when your going over bumps and not steering I doubt it's your steering rack. Is it like a rubber rubbing type of creaking sound?
Offline search
« Reply #4 on: 14 June 2012, 10:58 »
could be CV joint, rod ends, top mounts, suspension bearings, if you have cheap coilovers they could be leaking. even wheel bearing.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline jamesblonde
« Reply #5 on: 14 June 2012, 11:01 »
nah it sounds like metal creaking :S
Offline search
« Reply #6 on: 14 June 2012, 11:03 »
btw you sure you dont have power steering? just my cl 1.4 does you might need to top it up??
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline Dogbot
« Reply #7 on: 14 June 2012, 11:20 »
could have play in the shock leg, mine creaks & dongs like a git because i have a dead shock leg on the cheapo coilies
Offline jamesblonde
« Reply #8 on: 14 June 2012, 11:24 »
Nah definitely don't have power steering (got the guns to show it ;) )
I'll have a look in a sec to see what i can see.
