Author Topic: WMI pump locations...  (Read 1470 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« on: 13 June 2012, 22:04 »
Where do you have yours? With pics please, need some inspiration. I don't really want to lose the spare wheel if possible... :nerd:
Offline DunnDeal12
  • Limited
Re: WMI pump locations...
« Reply #1 on: 13 June 2012, 22:11 »
ive put mine where the charcoal canister used to be, with the tank in the boot
Offline mcgee9t2
« Reply #2 on: 13 June 2012, 22:18 »
could always put it in the little pocket type thing in the boot. think its made for a first aid kit to go in? on the pass side i belive...
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 13 June 2012, 22:56 »
only problem is I've read that the pump should be fitted lower than the tank due to the fact it pulls the liquid so gravity helps it...
Offline Dave_IOW
« Reply #4 on: 13 June 2012, 22:57 »
Wez, put it in the Well and put a can of that tyre weld stuff where the standard CD changer goes, clock is ticking!  :grin:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline DunnDeal12
  • Limited
« Reply #5 on: 13 June 2012, 22:59 »
cheers for that i didn't no. :cool:
Offline Dave_IOW
« Reply #6 on: 13 June 2012, 23:04 »
Mate, your going to love me, found this gem!
I'm thinking, where your old charcoal canister was, mount a small tank for wash fluid, use your existing tank in there for meth, and look at this for pump installation..
http://www.seatcupra.net/forums/showthread.php?t=336254
Offline DunnDeal12
  • Limited
« Reply #7 on: 13 June 2012, 23:23 »
spot on cheers dave
Offline jonrandom
« Reply #8 on: 14 June 2012, 06:56 »
Ive mounted mine in the bumper bar but it is a smaller aquamist and used the window washer bottle, hopefully the 3L wont run out to quickly. I have seen a larger 5L washer bottle someone was selling a while ago dont know what its from but it fits in so will look at getting that if it runs out to quickly.
Offline Steve_PD
« Reply #9 on: 14 June 2012, 19:43 »
5L washer bottle is off a golf with headlamp washers. Can order it from the dealers.
