Author Topic: Forged Pistons or Not?  (Read 4618 times)
Offline Chris.
« on: 13 June 2012, 19:10 »
Im on rebuilding my 1.8T ready for a T04e turbo.
I have a set of IE forged rods, piper vernier and a few other goodies.  I plan on running water Meth aswell.
I really need to know whether or not I should get a set of forged pistons aswell, or will the stock mahle AGU jobbies be alright?
Obvilously I get lower compression ratio aswell with a set of pistons aswell, which helps.
Anyone ideas?
Chris
Click For Build Thread
Offline DunnDeal12
  • Limited
Re: Forged Pistons or Not?
« Reply #1 on: 13 June 2012, 19:13 »
might as well if your doing everything else. :cool:
Offline Toby
  • Car - less
« Reply #2 on: 13 June 2012, 20:25 »
Might aswell! I need to do mine  :grin:
Currently down under
Offline Chris.
« Reply #3 on: 13 June 2012, 20:28 »
499 for wossner's.
Stock piston rings are 80quid so only really costing me 420 for the pistons.
8.5 compression ratio, and can go up to 82.5mm but I'd get 82mm making capacity: 1825cc up from 1781cc
Offline DunnDeal12
  • Limited
« Reply #4 on: 13 June 2012, 20:41 »
re bore??? take it to 2008cc
2.0 FSI crank
83mm pistons
sounds nice :cool:
Offline Chris.
« Reply #5 on: 16 June 2012, 12:54 »
Wont be going stroker.
Can get wossner or JE pistons for under £500, so which brand would people go for?
Both have 8.5:1 compression ratio from 9.5 standard.
Offline DunnDeal12
  • Limited
« Reply #6 on: 16 June 2012, 13:39 »
what about BAM pistons good for 500bhp and lower comp ratio of 9.0:1 and cheaper option than wossner & JE plus they use 20mm wrist pins
Offline Chris.
« Reply #7 on: 16 June 2012, 13:44 »
I could say agu ones are good for 400 but by time I buy new rings that's 80ish it's worthwhile going fully forged and even lower cr
Offline DunnDeal12
  • Limited
« Reply #8 on: 16 June 2012, 14:00 »
sorry dont mean hijack the thread but would you need a rebore to run the 82mm piston?
Offline Chris.
« Reply #9 on: 16 June 2012, 14:09 »
Yeah.  Stock bore is 81mm.
