Golf mk4
Wazzzer
Strange knocking noise - rev range 1-2K
Topic: Strange knocking noise - rev range 1-2K (Read 996 times)
Bish922
13 June 2012, 15:57 »
Hi there!
Noticed while driving along this morning a knockin maybe slight rubbing noise when driving slow between revs 1-2K. Sounds like its coming from gear box area while inside the car at least. It goes after 2K and not really there if I floor it. Clutch isn't slipping at all so just pondering if I should be worried about this!
Thanks
dan2252
Here all the time
Re: Strange knocking noise - rev range 1-2K
13 June 2012, 18:09 »
does it do it on idle? oil level ok? does it sound like its coming from the engine? if so could be bottom end?
MK4 golf 1.8 turbo agu
Bandit127
Here all the time
13 June 2012, 18:15 »
Does the noise go with engine speed or road speed?
Does it come back when you change from 3rd to 4th for instance.
If it goes with road speed then it could be CV joint(s).
Bish922
14 June 2012, 08:26 »
No its doesn't do it on idle. Oil is fine as far as I know I checked it about 2 weeks ago and it was ok, it is still there with road speed if you are listening out for it. What would you mean by bottom end?
Thanks
Bish922
14 June 2012, 09:52 »
Little update...... checked oil all ok. The noise is much more audible in 1st and 2nd pretty much non exisitant in 4th and 5th could this be related to the drive shaft?
1.6mk4GOLF16v
Here all the time
14 June 2012, 11:25 »
exhaust rattle perhaps?
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Golf mk4
Wazzzer
