Author Topic: MOT failure!  (Read 1261 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
MOT failure!
« on: 13 June 2012, 10:19 »
Just took the mk3 for its annual scrutinising and considering I've not had the chance to check anything over recently it didn't do to badly, Just needs the offside steering rack gaitor replacing which I'm glad to say is a cheap fix. Fingers crossed it stays dry at the weekend so I can tackle it now. :lipsrsealed:
Offline trog_nfs
Re: MOT failure!
« Reply #1 on: 13 June 2012, 10:29 »
at least you're not flintstoning it
Re: MOT failure!
« Reply #2 on: 13 June 2012, 11:40 »
Na which I'm pleased about, the tester commented on how solid and clean it was actually which is reassuring. I did get an advisory for some minor corrosion near the offside seatbelt mounting point though so when I'm underneath il have a butchers to see what needs treating before the rust takes hold.
Offline Screech16v
  • MK3 20vt AGU
Re: MOT failure!
« Reply #3 on: 13 June 2012, 21:26 »
Not bad at all  :shocked: ,that must be one well looked after golf  :smiley:
Re: MOT failure!
« Reply #4 on: 14 June 2012, 00:51 »
Had a look for the advisory, there appears to be some light scabbing just below the drivers door  rubber seal. A common place on these tbh, its still rock solid though so a good dose of Kurust and some touch up paint should do the job for now.
