Author Topic: Rear de mister not working  (Read 2218 times)
Offline balderz
« on: 13 June 2012, 08:42 »
Hopefully somebody can help my rear demister doesn't work and the switch on the dash doesn't light up the ars and hazards switches  both light up cheers
Offline mcgee9t2
Re: Rear de mister not working
« Reply #1 on: 13 June 2012, 08:52 »
Wire going from roof  to bootpanel broke.
thats were ide check first. most common
however the light on the button normally still works. just it changes colour...
Offline Ray_Ray280
« Reply #2 on: 13 June 2012, 13:08 »
have you checked the fuse??
Offline 1.6mk4GOLF16v
« Reply #3 on: 13 June 2012, 15:49 »
mine doesnt work neither but the light does come on the switch !
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Offline bullzeye
« Reply #4 on: 13 June 2012, 17:34 »
Mine stopped working months ago it stays lit bright but dosent de mist lol
cheapest mobile provider arround order a free sim with £5 credit www.giffgaff.com/orders/affiliate/s3cr3t
Offline mcgee9t2
« Reply #5 on: 13 June 2012, 22:16 »
that will be a snaped wire. common, happend on mine. just crimped it back togeather. 2 min job
Offline bullzeye
« Reply #6 on: 13 June 2012, 23:46 »
How easy is it to get to?  :angry:
Offline mcgee9t2
« Reply #7 on: 14 June 2012, 07:51 »
piece of urine.
normally snap in the grommet tubee type thing from roof to boot.  think its the one on the pass side. pull it out look for the wirre  thats snaped. re attach.
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
« Reply #8 on: 14 June 2012, 14:17 »
It was drivers side on mine wires are tight as though had to extend mine and solder.think it was the thicker brown wire and another one from memory.
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
