Author Topic: Water getting in my mk4 somehow?? Help anyone  (Read 3226 times)
Offline Wooosh
  • The Shocker.
« on: 12 June 2012, 14:50 »
I've noticed the past week that my mk4 front passenger side floorwell seems to be wet? Anyone have an idea what could be causing this or experienced this problem thereself :undecided:
Offline sveed1.8T
Re: Water getting in my mk4 somehow?? Help anyone
« Reply #1 on: 12 June 2012, 14:56 »
Have you got a sunroof?
Offline m4rt1ngti
Offline sveed1.8T
« Reply #3 on: 12 June 2012, 14:59 »
http://www.golfgtiforum.co.uk/index.php?topic=88604.0 :drool:
That is one possible reason for it...
Could be the sunroof though!? :wink:
Offline m4rt1ngti
« Reply #4 on: 12 June 2012, 15:00 »
Wouldnt the roof liner be wet in that case? I dont know i dont have a sunroof :cry:
Offline sveed1.8T
« Reply #5 on: 12 June 2012, 15:03 »
Nope, it's all to do with the drainage holes which go down the A pillar :smiley:
With the sun roof all the way open you will find the front drain holes in the corners. Give the holes a prod to try and cleen them up. If you open the front doors you will find a black ruber gromit inbetween the two hinges that sticks out. If you play with this by open you will probably get a lot of crud fall out of it. If you have a air line it would be good to blow down the drin hole and try and keep the ruber gromits open to pust the rubish out. Hope that helps :)
Offline m4rt1ngti
« Reply #6 on: 12 June 2012, 15:04 »
ooooooooo ill keep it zipped then  :lipsrsealed:
Offline Wooosh
  • The Shocker.
« Reply #7 on: 12 June 2012, 15:22 »
Ye mate mk4 3door with a sunroof? Have you had the same problem its annoying me now :grin:
Offline m4rt1ngti
« Reply #8 on: 12 June 2012, 15:24 »
Could still be the pollen filter cover tho! that would be my first check as its easier
Offline Wooosh
  • The Shocker.
« Reply #9 on: 12 June 2012, 16:01 »
Thanks for information will try check when i get home if its not still raining! The symptons sound the same everytime i go out it looks asif ive been dogging :grin:
