Author Topic: car ramps  (Read 2947 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
car ramps
« on: 11 June 2012, 12:18 »
are 8 inch (20cm) wide car ramps ok to use with tyre size 225/40 zr 18. Sorry if it is a dumb question, but I have never used them before, and just wondered if the ramps are suitably wide enough for my wheels
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline tech1889
  • Mk2 GTI FTW !!
Re: car ramps
« Reply #1 on: 11 June 2012, 14:58 »
I personally dont use ramps just jacks and axle stands
Offline Seanl
Re: car ramps
« Reply #2 on: 11 June 2012, 20:34 »
Thats probably because your a little lower than is possible to use a ramp!  :grin:
Offline tech1889
  • Mk2 GTI FTW !!
Re: car ramps
« Reply #3 on: 12 June 2012, 00:40 »
Most of the time yes  :grin: :grin: rest of the time im scared about driving off the end of em !
Offline rio_gti
Re: car ramps
« Reply #4 on: 13 June 2012, 21:02 »
more like not enough power to get up them  :grin:
Offline tech1889
  • Mk2 GTI FTW !!
Re: car ramps
« Reply #5 on: 13 June 2012, 21:10 »
What you trying to say.. my starlet would woop your cars ass lol
Offline EsSeX dAn
Re: car ramps
« Reply #6 on: 14 June 2012, 01:24 »
theyll be fine. might do well to drive onto some wooden blocks to avoid tearing ur splitter offd
i think i love you.....
Re: car ramps
« Reply #7 on: 14 June 2012, 19:58 »
Ok folks, I did it today, but after having a look underneath at the charge pipe and the hose to the pancake pipe, to remove them and replace with the agu version, (as mine is an aum) I thought stuff this, I didn't feel confident enough to do it while in that position. So I packed everything away and reversed her off the ramps, and then there was a massive CRUNCH sound  :sad: I looked underneath and seen the axle stand that I had put there for extra safety that I had forgotten to remove  :shocked:
I had ripped a hole in the engine cover splash guard, and luckily that was all the damage! This was mainly because I did it on a gravel/ stone chip/grassy/earthy driveway, so the axle stands dug into the ground. God knows what would of happened if I did it on a concrete driveway!!
Offline Xtrhardcore
  • Mk3 Gti 2.0 8v MoreDoor
Re: car ramps
« Reply #8 on: 20 June 2012, 13:07 »
Got off lightly there :wink:
Mk4 Gti - Gone but not forgotten!
