Author Topic: 1.8t clutch  (Read 1789 times)
Offline daubs
1.8t clutch
« on: 11 June 2012, 11:18 »
My clutch is slipping on my golf and I know the flywheel has been replaced with a solid single mass flywheel I was just after some info on what type of clutch I should fit as its also running 200 bhp any suggestions would be gratefully received
Re: 1.8t clutch
« Reply #1 on: 11 June 2012, 11:36 »
Go for the VR6 setup, lots of info here: http://www.golfgtiforum.co.uk/index.php?topic=87775.0
Offline Chris#101
Re: 1.8t clutch
« Reply #2 on: 12 June 2012, 12:48 »
What are you supposed to use if youve got a 6speed box ??   :laugh:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
