Author Topic: had a dream about my driveshafts............  (Read 2963 times)
Offline mush
« on: 11 June 2012, 10:27 »
as above I'm planning on removing both driveshaft's soon for my project and had a bad dream about it last night all the nuts broke off as i tried removing and were stuck in the block halting my project to an immediate stand still  :cry:
wasn't a good dream to be fair,
MK2 golf 16v :-)
Offline clipperjay
Re: had a dream about my driveshafts............
« Reply #1 on: 11 June 2012, 12:37 »
Plus gas FTW
Sounds like a nightmare TBF?  :grin:
Wait until you shear captive nuts then you will be in a world of pain!  :lipsrsealed:
Offline mk2bal
« Reply #2 on: 11 June 2012, 13:10 »
Just make sure you use multi spline bits and not torq, and hammer it in fully before you even think about turning them... Think the bit is the equivalent of a t40, but 2x the splines.. Vw still sell new ones and they're not too expensive, worth doing imo
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #3 on: 11 June 2012, 14:34 »
This thread honestly made me chuckle  :grin:
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #4 on: 11 June 2012, 17:11 »
You need to stop eating cheese before you go to bed :rolleyes:
Thom
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #5 on: 11 June 2012, 20:00 »
When I was taking my suspension off my other MK2 that has been "resting" for 12 years - a few years ago - I had to hacksaw through the nuts of the two mounting bolts.
Took 9 hours.
Nightmare.
 :huh:
Offline Bandit127
« Reply #6 on: 11 June 2012, 20:35 »
The thought of getting the rusty bottom bolts out of my rear engine mount without breaking them is bad enough...
I will stick to my 'junior' worries for the moment and graduate to drive shaft bolts in good time.
Offline lemski
  • 16v
« Reply #7 on: 11 June 2012, 21:51 »
M8 spline tool. Tap em in easy. If u can't get em out get a grinder n cut the heads of then u can turn em out after u removed driveshaft. no more nighmares about driveshafts now
Offline Seanl
« Reply #8 on: 11 June 2012, 22:07 »
Closest I've come was the caliper carrier bolts!  :sick: A bit of heat and a set of stilsons and I was able to leave my pants on.  :rolleyes:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #9 on: 11 June 2012, 22:52 »
Ive just bought two cans of plusgas to add to my collection as normally i just use bigger and bigger breaker bars till one works but my track rods seem seized so will persuade with plusgas see how good it is
