Author Topic: replacing a few bits  (Read 902 times)
Offline jims13
« on: 12 June 2005, 21:06 »
high, just got meself a 4 into 1 downpipe, which is a bonus as my standard one has a crack the size of the san andreas fault in it. any one done a rightup on how to fit one, im also onna be doing the gaskets on the rocker cover and a thermostat change and gasket at the same time, any time saving tips would be cool
cheers jim
jim
______________________________________
info@jpautomotive.co.uk
07747 004740
vag parts and tuning
Offline ...joe
Re: replacing a few bits
« Reply #1 on: 13 June 2005, 20:10 »
what engine is this? 8 or 16 valve? i've never done a 16 valve but 8's are a pain in the arse, as the inlet manifold tends to get in the way. rocker cover gasket is pretty straight forward on both engines and i can't think of any time saving tips, other than soak your manifold to downpipe bolts with oil for as long as possible before.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline jims13
« Reply #2 on: 14 June 2005, 00:00 »
ah well, its a 16v.  did the swap tonight,  the crack in the old cast item was massive, it went from half way across one pipe and then traveled down about 6 inchs to where the manifold ends.!!! :rolleyes:
anyway fitted the new one. ended up having to cut two pipes off as i couldnt get it throught the small gap .  started at 1700 , stoped at 1800 for dinner , started again at 6.30 and fineshed at 23.00..
didnt go to bad, and i now know how to do it quicker, cant wait till tommorow to c what a difference it makes. just need the rest of the zorst made now and then we will be sailing
jim
jim
07747 004740
