Author Topic: agu k03s more power  (Read 3501 times)
Offline Jayz
agu k03s more power
« on: 10 June 2012, 02:19 »
My agu k03s on a custom map runs 241bhp and 246 lbft torque but I've heard that i can get abit more by getting yellow calibre injectors or saab red injectors, vr6 maf housing 2.75" and using my 1.8t sensor? 255 fuel pump, forge actuator with a yellow spring and get the map tweaked is this true? is it worth it and will i get any more gains? (im after bit more torque really)
Offline golfyste
  • Project track car
Re: agu k03s more power
« Reply #1 on: 10 June 2012, 09:49 »
I have seen people with a bit more low down torque around 270ftlb but it also varies from engine to engine, buyin all them parts is a lot of money and I your unlucky you may only a extra 10-20 ftlb of torque ....
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 10 June 2012, 10:19 »
kin ell that must be pushing the standard injectors  :shocked:
Mine runs slightly lean on 225bhp  :huh:
I would fit the injectors/pump/MAF for safetys sake. Who mapped it mate?
Offline golfyste
  • Project track car
« Reply #3 on: 10 June 2012, 10:23 »
Sort just noticed you put agu k03s :grin:
My mistake, you probably will need maf and injectors, fuel pump will depend how good your is
Offline Jayz
« Reply #4 on: 10 June 2012, 19:27 »
Woody from east coast tuning, where can i get the injectors/pump and maf housing? if i change the maf housing will i have the change the silcone TIP or will i be able to squeeze mine on? and what about that actuator as im running a standard one?
Offline Jayz
« Reply #5 on: 10 June 2012, 19:39 »
how do you know if your fuel pump is good? and once i get all those bit do i get the map tweaked?
Offline Chris.
« Reply #6 on: 10 June 2012, 21:42 »
Cant see that running 241bhp without injectors, bigger MAF and fuel pump.
OEM MAF is out of scale at 233bhp ish.
Click For Build Thread
Offline golfyste
  • Project track car
« Reply #7 on: 10 June 2012, 21:52 »
I think really it's down to luk some are goo enough and some are worn and can't handle, dunno how you could test, I you jar te budget just get an uprated one.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 10 June 2012, 21:58 »
depends on mileage with actuator, I changed mine as it was a little bit bent  :lipsrsealed:
They're all old now and running higher boost shortens the life a bit too
Yes you'll need map tweaks so the parts will need fitting at your tuners, not before you get there
Offline Jayz
« Reply #9 on: 10 June 2012, 22:23 »
well it is its been on rr, same way you claim yours is running 248bhp  278lbft.
golfyste & wazzer: i'll get the bits and get it done any ideas where to get the fuel pump and injectors?
