Author Topic: foam arch sound insulation  (Read 4419 times)
Offline mkviken
Re: foam arch sound insulation
« Reply #10 on: 11 June 2012, 09:33 »
th new ones have a kind of skin on them but its not fully water proof it seems.
maybe something like that would work but maybe it would just flake off?
it should be made out of polystyrene like the insulation under the bonnet IMO.
Golf GTI 7.5 230 white silver
Offline mike.
« Reply #11 on: 11 June 2012, 11:11 »
I thought that sponge was to help soak up water to prevent ice build up behind the door causing the problem that happened on the MK5 in cold countries.
With ice formed behind the leading edge of the door there was nowhere for the door to go when you opened it so it bent.
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Ginge 35Edition
« Reply #12 on: 11 June 2012, 16:56 »
Ouch!
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #13 on: 11 June 2012, 18:37 »
Mk5 in harsh climates have a hole were the mk6 foams can he seen.
The foam if it sokes up water will freeze too.
If it did not soke up water it would flex and give to allow somewere for the ice to go.
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline Will@carbon
« Reply #14 on: 12 June 2012, 00:50 »
Sorry I'm a little lost, why does it matter that it soaks up water?
Just asking.
I don't believe in global warming, sorry.
How are speed bumps legal?
I dislike lorry drivers who block lanes in traffic.
All burglars must die slowly ASAP.
Offline Jimble
« Reply #15 on: 12 June 2012, 08:48 »
Just asking.
It's the potential for corrosion inside the wing if the foams hold water.
Offline Will@carbon
« Reply #16 on: 12 June 2012, 15:22 »
Omg your right, that's bad! Who did that happen too? Poor bugger.
Offline Rhyso
« Reply #17 on: 12 June 2012, 15:41 »
it seems to be happening to MK5's....... :sad:
Offline Will@carbon
« Reply #18 on: 12 June 2012, 15:55 »
That's daft. I thought merc owned the rights to rusting.
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #19 on: 12 June 2012, 22:20 »
Behave you  :lipsrsealed:
