Author Topic: '91 2.0lt 8V GTi -- poor cold starting...  (Read 2960 times)
Offline mk14dr
« on: 09 June 2012, 22:08 »
Firstly, I ALWAYS wait for the fuel pump to prime before cranking.
The first time this happened, I'd come out from work after a torrential downpour, jumped in, started it as normal, it caught and ran for 2/3seconds then died.
I then proceeded to spin it over in hope, it seemed to try to catch/fire but only when it'd been spinning over for 15-20secs did it make any real effort to run (but not actually run, if you know what I mean)
I almost completely flattened the battery that first time, but I had the foresight to wait for 5mins and have a cig before trying it again and low and behold it started (albeit running on 3pots) so I held the revs at 3k until it got warm before driving 250miles to a music festival.
After being parked for a week in a field, I wasn't expecting much, but it fired up dying almost instantly. I waited 20mins, went back to it and it started and ran fine the 250miles home.
Since then its done it everytime when started from cold. Sometimes if it catches and I'm on the throttle quickly enough I seem to be able to keep it running with liberal right foot, but it sounds like its running on 3 maybe even 2pots.
It has also, once, started normally then cut out 1/4miles down the road only to restart immeadiately.
As soon as there is even a hint of heat in it it behaves perfectly.
I'm gonna stick a fully charged battery and new fuel filter on it tomorrow to see if it makes ANY difference, but I have a feeling Ive heard about an issue like this being caused by a temp sender before....
« Last Edit: 09 June 2012, 22:21 by mk14dr »
Offline Mr Blue
Re: '91 2.0lt 8V GTi -- poor cold starting...
« Reply #1 on: 09 June 2012, 22:19 »
Do a search for Blue Temp Sensor. Might be the problem  :smiley:
Offline mk14dr
« Reply #2 on: 09 June 2012, 22:27 »
Yeah, that sounds about right does that. Lets hope its something so simple...
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #3 on: 09 June 2012, 23:36 »
Start with the basics, have a drop test on the battery, thinking the battery is OK is different to it actually being at the top of its performance, and can make all the difference...
Next, if the battery is OK, change the plugs for decent OE spec, and good quality HT leads, Dizzy cap, and rotor arm, all these things are associated with poor starting in damp weather...
Thom
Offline mk14dr
« Reply #4 on: 10 June 2012, 00:31 »
I'll have a look at the ignition side of things tomorrow afternoon, but it doesn't seem to be directly linked to rain or even damp.
It seems to be more to do with the engine being cold, as, like I said, as soon as there is the merest hint of warmth it behaves itself.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #5 on: 10 June 2012, 03:33 »
As Thom says & worth changing the Blue temp sender for me;
http://www.golfgtiforum.co.uk/index.php?topic=216745.0
« Last Edit: 10 June 2012, 03:35 by X4MGS »
For More Info Click To See;
