Author Topic: mk3 gearbox flang to mk4 gearbox  (Read 2745 times)
Offline lemski
  • 16v
« on: 08 June 2012, 19:24 »
Hi, do the 02j flanges come out? I think that's what gearbox is. Its out of an early a3 turbo. I need to know so I can get my mk2 back on its wheels. Cheers all
Offline clipperjay
Re: mk3 gearbox flang to mk4 gearbox
« Reply #1 on: 08 June 2012, 19:30 »
With the 1.8t there are 2 flanges available either 100mm or 108mm, if its 100mm all is well mk3 shafts vbolt up. if 108mm then you need to swap the shafts for early 02j or 02a. there are 2 types of flage bolt in and clip in just need to get the right type
Offline lemski
  • 16v
« Reply #2 on: 08 June 2012, 19:34 »
Al measure tomorow jay. I owe u a pint wen I see u at a show. 4 reg means early dunt it?
Offline clipperjay
« Reply #3 on: 08 June 2012, 19:35 »
Might do as 2000 onwards is considered early so 2004 would be check if its a clip or bolt type fella?
Offline lemski
  • 16v
« Reply #4 on: 08 June 2012, 19:40 »
What u mean clip or bolt. If it helps its bolts up as mk3s do, but has m10 heads instead of m8
Offline clipperjay
« Reply #5 on: 08 June 2012, 20:01 »
Two type of flanges I think ones is plastic one is metal the metal type should be bolt so when you order one for that box mention its a bolt type! But we need to defo find out total length of the drive shaft to confirm its 100mm type?
Offline lemski
  • 16v
« Reply #6 on: 08 June 2012, 20:04 »
Ill find out tomorow and I will txt you buddy. I owe you jay
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #7 on: 09 June 2012, 14:34 »
early 20vt, will be 100mm bolt in type
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline lemski
  • 16v
« Reply #8 on: 09 June 2012, 17:28 »
Sorted it now. Didn't even change the shaft
