Author Topic: 16v backfire/cutting out  (Read 3949 times)
Offline jonny-5
« on: 08 June 2012, 17:54 »
Hi, i've had this problem for a few days now on my 9A converted mk2. It is that when I'm driving on part throttle occasionally the rev counter will drop to zero and the engine dies for a second and then bursts back into life often with a loud backfire out the exhaust!
It doesn't seem affected by operating temperature, car drives perfectly under load and wide open throttle, starts perfectly. I've tried a known good coil and distributor to no avail, have also recently changed the plugs, leads, dist cap, also changed almost all the short flexi vac hose joiners, cleaned the metering flap and throttle body.
Any idea where to go next? The thing is driving me mad!
Offline Diamond Hell
  • Opinions я Us
Re: 16v backfire/cutting out
« Reply #1 on: 08 June 2012, 18:00 »
[broken record]
Check all of your earths around the engine bay
[/broken record]
If the rev counter's going to zero then the electrics are dying momentarily and then coming back in - you suddenly have no spark and fuel still going in and then spark and LOADS of fuel BANG!
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #2 on: 08 June 2012, 18:11 »
[broken record]
[/broken record]
Ditto... broken wire, loose earth, plug not on properly, maybe the loom is pulling on a plug when you give it gas, that sort of thing
Thom
Offline jonny-5
« Reply #3 on: 09 June 2012, 16:18 »
Been checking round today, cleaned all the earths I could find. The problem remains! It's definitely when you just come off throttle and then again when you put it back on. As I said it doesn't do it all the time but it's pretty much most of the time when driving with very little throttle and doing the above.
Cheers so far but any more help?
Offline jonny-5
« Reply #5 on: 09 June 2012, 17:12 »
That was my thought too. Did the test as per the Haynes book and all appears to be in order. Don't see how that could interupt the spark system though
Offline jonny-5
« Reply #7 on: 10 June 2012, 21:09 »
Tried 2 different known good distributors so would rule that out. Swapped the king lead over today for another good one - no difference. Gunna try a new cap next
Offline clipperjay
« Reply #8 on: 10 June 2012, 21:50 »
Fuel pump can sometimes give that symptom check the lift pump?
Cold or warm when it does it?
  • Opinions я Us
« Reply #9 on: 10 June 2012, 22:44 »
Swap out the earth from the head to the coil.  Earth straps can sometimes fail, so I'd still be chasing that some more before following other routes of enquiry.
