Author Topic: Electric Windows  (Read 1881 times)
Offline Dizzie
  • Make friends with your fast
Electric Windows
« on: 02 October 2003, 15:20 »
I've just got a loom consisting of 2 switches, a relay and a fuse ready for when my new doors get sprayed and fitted.
I can see that 1 wire goes to the earth and 1 to the live, but there are 2 others coming from the relay that I have no idea where they go.
Any help guys :)
Offline Helios_Blue_Valver
Re:Electric Windows
« Reply #1 on: 02 October 2003, 22:42 »
are the switches already wired into the relay? I maybe wrong on this but from what I have seen before you should have a wire for earth, one for power and the last 2 should be the wires to the door motor. are they original VW parts or an aftermarket kit? I'll have a look in my manuals when I get home and see what I can come up with. take care,
Brad
Offline Ant
Re:Electric Windows
« Reply #2 on: 04 October 2003, 16:38 »
Sort of got my drivers side window working, the motor was disconnected, reconnected it, and motor worked no problems, but still no window.
Looking at the guide plate discovered it had been cable tied at the top, removed them and the window goes up (no problems) and down after a fashion.
I'll try to explain futher but with out the technical names I'm finding it hard to discribe.
The guide wire is not connected to the liftingplate, the window rises because the joining bolt hooks up against something in the lifting plate. When going down the bolt drops rapidly but the window drops under gravity.
I would assume that the bolt (or some other item) should actually be attached to the lifting plate and therefore pull the window down in the same fashion as it raise's it.
Is this correct? If so how do I connect it up properly, will I have to remove the guide rails and window to do it?
« Last Edit: 04 October 2003, 21:58 by DakoYam »
