Author Topic: ABS PUMP  (Read 1604 times)
Offline stroodlion
ABS PUMP
« on: 12 June 2005, 17:05 »
Hello i need a new abs pump for my 96p vr6 there is two for sale on ebay one has the number 1h2614217b and the other has 358614217 does anyone know if any of these will fit my car
many thanks :sad:
Offline AudiA8Quattro
Re: ABS PUMP
« Reply #1 on: 14 June 2005, 09:27 »
Neither will fit.
The first part no doesn't exist, the second is for a passat 92-93.
Check the 10th letter of your chassis code, should be a T.
If so then the pump you want is an ATE with code 1H2 698 117.
Offline stroodlion
Re: ABS PUMP
« Reply #2 on: 14 June 2005, 22:21 »
Hello thanks for the info but 10th letter on my chassis is a v
Any more ideas.
many thanks :sad:
Re: ABS PUMP
« Reply #3 on: 15 June 2005, 18:06 »
Same parts will apply as your model is one of the later ones.
