Golf mk2
will this 4 branch fit straight on my 16v??
Topic: will this 4 branch fit straight on my 16v?? (Read 4069 times)
01664gti
mk3 hatch mk3 wagon and mk2 16v
07 June 2012, 18:16 »
Hi all
I went and fetched this from a forum member for my mk2 16v today.Before i take it to the boys to get it on i just wanted to check its right
Will it just bolt straight on??
clipperjay
Re: will this 4 branch fit straight on my 16v??
07 June 2012, 18:18 »
Really can't tell mate the bulk head clearance on that bend is hard to judge without fetting up
http://www.golfgtiforum.co.uk/index.php?topic=170521.0
http://www.golfgtiforum.co.uk/index.php?topic=55336.msg427955#msg427955
01664gti
07 June 2012, 18:21 »
Ah ok sorry my bad,Its the other end which i was more dubious about tbh.
What i mean is does a standard 16v exhaust have the same fitting in the end?
Last Edit: 07 June 2012, 18:42 by 01664gti
clipperjay
07 June 2012, 18:42 »
You want to know the bolt to bolt hole on a standard 16ver?
Center bolt hole to butt hole is 3" to each manifold port.
Each total width of each port end to tip is 9.5cm
Total width end to end on all four is 32CM
Hope that helps!
Last Edit: 07 June 2012, 19:03 by clipperjay
01664gti
07 June 2012, 19:11 »
Cheers for the info buddy,
What i meant was is a mk2 gti 16v a sleeve/clamp or does it bolt up to the front/centre pipe
Wayne
Sir Postalot
08 June 2012, 00:16 »
That looks like a mk1 16v conversion manifold made by Ashley, they had the same flange on the end.
Diamond Hell
Serious forum addict
Opinions я Us
Reply #6 on:
08 June 2012, 09:21 »
Could be for a Golf3 - they have that flange on the cat.
01664gti
Reply #7 on:
08 June 2012, 15:23 »
It was off a mk1 one with a 16v in it,I only found out today.Will it still my car tho as mines mk2??
Wayne
Sir Postalot
Reply #8 on:
08 June 2012, 15:38 »
Quote from: 01664gti on 08 June 2012, 15:23
Don't think it will fit.
01664gti
Reply #9 on:
08 June 2012, 15:50 »
bugger!! best sell it and get a proper one then lol
Golf mk2
