Author Topic: brake pad sensor  (Read 784 times)
Offline dhorsfall2000
brake pad sensor
« on: 07 June 2012, 15:46 »
hi, my wire to the brake pad sensor has snapped right at the connection, only way i can think of fixing is to get another from scrapyard and hiding the the joint inside the protective plastic sleeve, any other ideas would be appreciated.  :sad:
Offline opel
Re: brake pad sensor
« Reply #1 on: 07 June 2012, 20:53 »
cut the connection off both and strip the wires both ends and join them with straight connections. if u dont wont it at all cut the wire of the brake pad and just strip the wire behind the connection that comes of the car and join wires together and it will switch the light off
« Reply #2 on: 08 June 2012, 14:49 »
nice one, didnt think of that
