Author Topic: intermittant rev limiter problem  (Read 1688 times)
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
« on: 06 June 2012, 12:31 »
I have just took a mk3 gti in as a trade in,It was fine on test but now seems to randonly decided to only rev to about 5k and then hit the limiter.It can be fine one minute and then play up another.
I did a search but it came up about timing being out,Surely if this was the case it would do it all the time.
its an agg 8v so nothing special,I have tried my vagcom and it cant connect to vehicle
Any help with this would be great
Offline lem0nmonkey
Re: intermittant rev limiter problem
« Reply #1 on: 10 June 2012, 11:37 »
if its intermitant id go with the hall sensor on its way out, or the wiring? if it was all the time then the timimng or dizzy would have been mis aligned.
the 5000rpm limit is a safe mode to stop the car lunching itself, knowing theres a timimng issue
Offline Screech16v
  • MK3 20vt AGU
« Reply #2 on: 10 June 2012, 15:45 »
Yeah sounds like hall sensor in the dizzy,throw a known working dizzy in there ,that should sort it  :smiley:
Offline 01664gti
« Reply #3 on: 10 June 2012, 19:58 »
ok guys cheers,Ill see if i can find one breaking local
